Erratic lights
Old Sep 30, 2008 | 02:29 PM
grm's Avatar
grm
Default Erratic lights
My friends 300 Sportsman had the battery terminals reversed, After that his lights ( brightness ) goes up and down. I haven't checked anything yet. It will start by pulling on the starter rope. I am looking for advice on what to check out first. Any advice is appreciated. thanks grm
Old Sep 30, 2008 | 10:15 PM
Possible shorted battery with terminals reversed! ALSO lights will flicker if battery wont hold voltage,charging from reg/rectifier has to go somewhere if battery bad,lights are first to take the excess voltage and usually will burn out if problem not fixed. Good luck
Old Sep 30, 2008 | 10:27 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Will the battery hold a charge?
If so........Chech the battery with a volt-meter and should get near 12 volts
Then start Quad up .....Check again while running......Should be higher......13-14 volts....
Don't know if that year has a separte Reg/Rectifer........I had one go in my old Yamaha Exciter Sled and the headlight would go bright and blow out after using for a short time.......Caper.....
Old Oct 1, 2008 | 01:03 PM
grm's Avatar
grm
Thanks for the reply, What procedure do you do to check to see if the rectifier or regulator is bad? The battery has been changed twice so I imagine that is not the problem. Thanks again. grm
Old Oct 1, 2008 | 01:11 PM
RolliePollieOllie's Avatar
Also make sure the connections are nice and tight and the battery from when he changed them over. A loose ground connection will cause this.
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
