Winter
Old Oct 9, 2008 | 07:03 PM
DARETORIDE's Avatar
Default Winter
What should i do to my quad to get it ready for winter?? i do not drive it during the winter because i use the old quad and sled in the winter...
Old Oct 9, 2008 | 07:21 PM
scrambler400enoge's Avatar
Shapeshifter Rider
Default Winter
While I don't prepare in any way I like to up the fuel from regular to premium in cold weather and always give it a proper warm up no giving it gas while warming up thats what I do.
Old Oct 10, 2008 | 12:29 AM
HeftyLefty's Avatar
Default Winter
Storage Tips:
Read owners manual for model specific tips, but generally I would:
Drain the gas from the tank, it will be junk by Spring anyway. If leaving gas in tank, add Stabil or similar to gas.
Shut off fuel petcock and let quad idle till it dies. This drains carb and float bowl so no gunk in them in the Spring.
Fill all grease fittings with fresh grease. This is so the old moisture filled dirt loaded grease doesn't spend the winter corroding parts. Do the same with wheel bearings.
Plug up exhaust and air intake to keep 'critters' out.
Drain old oil from crankcase. Again so it doesn't spend the winter damaging engine. You ARE going to change it in Spring anyway, aren't you?.
Clean and lube all that moves on the quad, steering shaft bushings, control cables etc. Again to stop corrosion.
Clean brakes with brake cleaner.
Check coolant, make sure it's fresh and will keep quad block from freezing.
Remove battery and put on battery tender, or leave in place and put on battery tender.
HTH
Old Oct 10, 2008 | 12:35 AM
biz4two's Avatar
Default Winter
What HeftyLefty said!
+Plus+ wash the ATV from top to bottom. I like to add 5-6psi more air than recommended in the tires. Unless you plan on checking then during the winter months...and adding as necessary.
Hope this helps...
biz
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 10, 2008 | 01:18 AM
Shapeshifter Rider
Default Winter
Oh storage sorry what hefty lefty said but thats what I do to Ride in the winter.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
byronman
Sep 6, 2015 06:34 PM
Sep 1, 2015 01:45 AM
