Brand new 07 sportsman 800
Well just my luck, finally got the o.k for the new 800 so I picked it up tonight, take it for a ride and 4 miles later it's gotta go back to the shop. I stopped in the woods to switch into low and it stalls. Crank and crank and nothing. Let it sit a couple minutes and it fires up, so I come back home. Pull it into the shed and it's smoking smells like a mix of oil, plastic and gas. Wondered if I should get a fire extinguisher. Well I'm looking around and pull the side panel and it's starting to melt like I was well aware of and while I'm looking I see something in the airbox drain. Pull the seat and airbox and it's full of a black liquid. Looks like a mix of gas and oil (smells like it to). Pull the filter and its soaked, the bottom is all black like oil soaked. So I take some pics and load it back up on the trailer for it's ride back to the dealer. Curse of the Rowe luck. Now I love Sportsman but every new one I buy I have had to take back the very next day for them to fix something. I know we'll get it worked out but damn what a downer!!
My question to you guys is what the hell would have caused that? Has it ever happened to any of you? Are there any service bulletins for this model? Any advice you could give me would be great. I have been looking over the 800 posts for quite sometime but don't remeber reading anything like whats happened to me. Thanks guys!
I wonder if there is a blockage somewhere...With only 4 miles........If the oil is not flowing...ex. plugged oil filter or oil line, The pressure line off the top of the tank will push the oil out into the airbox(or slit in top hose)........But with only 4 miles that oil in there should be the same color........Caper.........Keep us posted please....
Next time you buy a new one ride it around their lot for the day since you know you're going to have to bring it back anyway after something malfunctions! LOL! Or, go for a short ride with someone else who is prepared to tow you back.....sorry, no help, but couldn't resist. You must have the same luck as me, so I know the feeling very well! Good to know I'm not the only cursed atv fan out here!
my 05 800 melted the plastic and the seat. I think its a common problem with the 800. The two exhaust run to close to the plastic on the right side. I found that if i keep my air filter changed it doesn't get hot. i i dont know why you have gas and oil in your air box but i would say that your filter being wet is why it got hot. A wet filter doesn't let as much air in causing the engine to use more fuel, in turn raises exhaust temps. Just my theory. Does this make sense to anyone?
