Killed the new 850........already.
<div class="FTQUOTE"><begin quote>Originally posted by: WOLF1
Not really the machines fault though. I was playing in a mud hole sunday and broke the left front cv axle. The front end was then locked up, winching it out was very tough. The right rear tire went flat due to unknown causes at the time, but now I know what happened.
Anybody curious?</end quote></div>
I'm very sorry to hear about your ride, and I hope you have it back on the trail soon.
IronBear
IronBear
Are you the same WOLF1 that posts over on atvrideronline? http://forums.atvrideronline.c...ris-bashing/index.html
<div class="FTQUOTE"><begin quote>Originally posted by: Whiner
Are you the same WOLF1 that posts over on atvrideronline? http://forums.atvrideronline.c...ris-bashing/index.html</end quote></div>
Not unless he had a 180* change of heart..he has posts from back in sept where he said he had a popo and said nothing negative..
Also this thread...
http://forums.atvconnection.co...54188&highlight_key=y
I just realized this is the same guy..if you read post at the bottom I said "It sounds like if there is a weakness with the XP you will find it" lol
Sounds like where he rides is a very harsh enviroment and he cuts a machine no slack.(No negativity intended Wolf, It's your machine and you admitted it wasn't the machines fault)
Also this thread...
Hmmm.....I wonder if we'll hear of more of this type of trouble? If the clearances are that tight with the wheel/brakes its bound to be bad news, maybe a design flaw.
#15
I must be missing something here. I measured my 850 today and there is an 1 1/4 between the inside of the spokes and the disc and they are set well into the wheel itself. How could a small rock effect this area? I'm curious.
Take care,
Dave
Take care,
Dave
#16
first couple of rides on my 06' 800 i was in a bad hole and snap a cv joint basicly the same way. these in low range has masive torque and something is going to give and the cv's are the weak link.
#17
<div class="FTQUOTE"><begin quote>Originally posted by: 600Grizzly
Take care,
Dave</end quote></div>
The clearance problem is not between the spokes and rotor. Its between the top of the brake caliper and inside of wheel.
Take care,
#18
Nope, thats not me.
Nope, thats not me.
#19
<div class="FTQUOTE"><begin quote>Originally posted by: HIGHOCTANE
Also this thread...
<a target=_blank class=ftalternatingbarlinklarge href="http://forums.atvconnection.com/messageview.cfm?catid=11&threadid=554188&highlight _key=y
">http://forums.atvconnection.co...highlight_key=y
</a>
Sounds like where he rides is a very harsh enviroment and he cuts a machine no slack.(No negativity intended Wolf, It's your machine and you admitted it wasn't the machines fault)</end quote></div>
Yep we do ride hard and in very demanding conditions. In Idaho we have a wide range of terrain, huge mountains, open desert, mud, snow, rocks and we ride it all.
We push our machines to the limits regularly, and use our winches alot. But, thats why we buy them, and fix them!
Also this thread...
</a>
#20
Wolf 1 would this mean that offset rims would cure a problem like this? Sorry to hear about your ride being down. Are the new items needed available to you through your dealer or do they have to order everything in.
Take care
I don't think offset wheels would help as much as bigger wheels, but they are already 14" so thats kinda hard to accomplish.
All the parts I need have to be ordered in nothing in sock or interchangeable from previous years.
Take care
