Carb adjustment help
Old Nov 24, 2008 | 05:49 PM
chikester's Avatar
Default Carb adjustment help
Finally got my 2000 Polaris Sportsman 500 carb cleaned out and put back on. Started right up but is now idleing way too high. I adjusted the long adjustment screw that hangs down and has a **** on the end, but it did not bring it down much. I assume I need to adjust the screw that I need a small screwdriver to adjust with. Is this correct? I cannot get my hand up there with a screwdriver, any tricks? Thanks
Old Nov 24, 2008 | 07:05 PM
If idle wont come down with adjuster,probably have throttle cable too tight! Adjust slack at throttle first with adjuster on the cable to where slack is about 1/8" slack at thumb throttle,then adjust idle screw on carb. might help
Old Nov 24, 2008 | 07:25 PM
chikester's Avatar
could you please tell me how I adjust the throttle at the thumb. Thanks.
Old Nov 24, 2008 | 07:36 PM
On throttle cable is a rubber sleeve,pull back and you will see plastic locknut,loosen nut,adjust cable to where you FEEL about 1/8" slack at thumb throttle,then tighten locknut.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
