03' Trailblazer 250 hard start issue... again.
Old Nov 29, 2008 | 02:41 PM
flystiguy's Avatar
Default 03' Trailblazer 250 hard start issue... again.
Ok so i posted a few months ago with a no starting issue and found out that i had almost no compression so i rebuilt the top end and it ran great until i took it out on some trails and got some mud and water into the carb(one of the clips missing of the airbox and a rip in the carb inlet boot) So now i just funished cleaning the carb and it will start and then if you let it sit for about 15 minutes it wont want to start again. Anybody got any ideas?
Old Nov 29, 2008 | 04:36 PM
eggenz7's Avatar
sounds like the float is not set correctly. i would double check that its not filling up the crankcase with fuel causing it to flood out
Old Nov 29, 2008 | 04:50 PM
flystiguy's Avatar
Ok, so how do i set it correctly? I dont have a service manual so im kinda just geussing at everything.
Old Nov 29, 2008 | 05:50 PM
flystiguy's Avatar
Anybody? Really trying to get this adjusted tonight as me and a bunch of other people are trying to go riding tomorrow.
Old Nov 29, 2008 | 07:05 PM
eggenz7's Avatar
take the carb off and set it on a flat table upside down. take the bowl off the carb and look at the brass float. should be parallel with the carb body maybe slightly pointing up away from the carb. if its not set right bend the tab that makes contact with the float needle.
Old Nov 29, 2008 | 11:08 PM
ftwflh's Avatar
Check exhaust for water
Old Dec 2, 2008 | 11:42 AM
flystiguy's Avatar
So, If the oil injection wasnt working, would the quad still run? We took it out riding this sunday but the whole time we were out there(good 4-5 hours) Me or my riding buddies didnt notice any smoke coming out of the muffler. Two strokes are supposed to smoke right?
Old Dec 2, 2008 | 10:11 PM
eggenz7's Avatar
no smokey in exhaust:
1. too little oil
2. just the right amount of oil
3. smokeless 2 cycle oil used
the easiest way to check the oil injector is the take the small tube loose from the motor and runs from the top of the pump to just below the intake boot on the cylinder. empty the fuel system and put some 40:1 premix in it. start the motor and rev it just slightly. there should be a drop of oil come out of the little tube every few seconds. to recalibrate it, there is a mark on the injector body and a mark on the part the cable connects to. those two marks should be lined up when the bike is just at idle. the cable should move with the slighest pressure on the throttle
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
02Chevrolet
Jun 23, 2015 12:12 AM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
