03 Sportsman 700 woes
Old Dec 13, 2008 | 07:44 PM
Newfygarge's Avatar
Default 03 Sportsman 700 woes
choke is working good. I've got to track down someone with equipment to do compression test.
Would a bad diaphragm in the fuel pump cause this, it doesn't look perfect, looks a bit stretched in one spot.
Old Dec 14, 2008 | 11:30 AM
upnort's Avatar
Can download a 2003 shop manual here (250 megs)
http://www.megaupload.com/?d=Y1A3JT0Z
Old Dec 14, 2008 | 01:48 PM
H20's Avatar
H20
You must check your main jets. They can come loose or completely fall out.
Old Dec 16, 2008 | 01:22 PM
Newfygarge's Avatar
Main jets seem tight enough. I can't turn in any further.<div class="FTQUOTE"><begin quote>Originally posted by: H20
You must check your main jets. They can come loose or completely fall out.</end quote></div>
Old Dec 16, 2008 | 01:26 PM
  #15
Trukinbear's Avatar
Ya never know, I would replace the diaphram in the fuel pump if it looks worn.
Old Dec 21, 2008 | 10:43 AM
  #16
Newfygarge's Avatar
Went to dealer to see if I could purchase the diaphragm, but of course didn't have one & don't have a part #. A new fuel pump will cost $60 plus 13% taxes. Will an after market fuel pump work? If so any particular kind or type??. Thanx
Old Dec 21, 2008 | 10:48 AM
  #17
eggenz7's Avatar
i believe napa has a plug and play pump for like 12 bucks i believe. take the pump off and bring up there..they can cross reference it
Old Dec 21, 2008 | 11:03 AM
  #18
DCT's Avatar
DCT
Banned
If all the other stuff is good, I would guess that the needle is stuck and flooding the carb. Maybe the enrichment plunger... but I doubt it. If it were mine, I'd probably try to find a new carb for it, or completely rebuild the existing one.
Old Dec 21, 2008 | 02:53 PM
  #19
Trukinbear's Avatar
http://cgi.ebay.com/ebaymotors...Item&item=220330688336
Old Dec 28, 2008 | 11:29 AM
  #20
Newfygarge's Avatar
UPDATE
Well had carb rebuilt and had a loan of a fuel pump & everything was the same no improvement or very little. Decided to drain oil & it was grayish with traces of green in it (yes antifreeze). Keep in mind this atv hasn't been through water since oil change not even a puddle. So it is antifreeze that is getting into base, & back to the breather box, no antifreeze comes in or out of the bottle on the side, but yet the antifreeze is down about a quart. Must be a seal problem, does anyone know where?? Or what else it might be?? Thanx
