2000 TB not wanting to run right
Old Dec 13, 2008 | 03:25 PM
eggenz7's Avatar
Default 2000 TB not wanting to run right
if i push the throttle in all the way it will fire up and run at just above idle. if i let off of the throttle at all it will die.
if i take the air box lid off while it is running like that, and back off the throttle just a little bit, it will start to run like normal but still will not idle. i have tried adjusting the pilot screw i check the ETC and i cant figure out what is going on here. any ideas?
Old Dec 13, 2008 | 05:35 PM
eggenz7's Avatar
well after i fixed the exhaust leak tore carb apart and stuck a different pilot jet in (same size just a different one) and put a different brass float lever in put it all together and it runs like it should now.
now i dont have to sit at home tomorrow while my buddies are out riding [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 14, 2008 | 02:16 AM
war1ock's Avatar
haha glad u figured it out
Old Dec 14, 2008 | 08:35 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just make sure you didnt lean it out too much w/ the air screw.
Old Dec 14, 2008 | 09:59 AM
eggenz7's Avatar
set the air screw back to what is supposed to be
rcappie4
Jul 18, 2015 07:51 AM
Peter_
Jul 18, 2015 07:06 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
