HD springs (Front)
Hey R, I got the Polaris hd springs for the front of the X2. I have a winch but not a plow. It really improved the ride and went from too soft to a little stiff suspension-wise. It steers better than when the front end would dive and sag. I like it better in the whoops now and it is excellent going downhill. No more bottoming out the suspension.
#17
For the set correct?
Did you install yourself? If so, how much of a job was it? I know some have used the small tie downs to compress the springs.
<div class="FTQUOTE"><begin quote>Originally posted by: MooseHenden
The price was right for the Polaris HD springs. Around $50.</end quote></div>
#19
Rick, although I try to read these forums regularly, I typically do not lend any insight to the questions being asked. In this case however, I will try to help. I have a 2003 500 HO and a County Plow. I had a sagging problem and I installed the EPI springs and they cleared up the problem immediately. I did give up some ride comfort but the squatting was virtually eliminated.
Hope this helps
Hope this helps
