Scrambler is bleeding!
Old Dec 29, 2008 | 09:38 PM
firemedicsafd's Avatar
Default Scrambler is bleeding!
I have a 97 scrambler that is bleeding fuel from the exhaust manifold and will not start. But it only bleeds when i try to start it. I have taken the carb out and cleaned the crap out of it with no help. The carb is of the same design but it is out of a 01 sportsman. Everything hooked up right and it ran good for a while...now its going nowhere. Can anybody help me? Thank s alot!
Old Dec 29, 2008 | 09:46 PM
eggenz7's Avatar
sounds like the choke circuit is stuck open. the way choke works on these is really a "fuel enricher" system. in layman's terms it dumps more fuel into the crankcase. your plug could also be slightly fouled because the pilot jet is too big in the carb. it ran fine for a while until the plug got fouled now it wont start. have you tried spraying carb cleaner in the intake to see if it will fire off?. try turning the fuel supply off then try to start it.
there is also a drain the bottom of the crankcase. if there is too much fuel in the bottom then it wont fire off either.
(btw im assuming these are the 400 2-stroker motors your talking about)
lots of possibilities.
Old Dec 29, 2008 | 09:56 PM
God no!. I am talking about the 500 4x4 4 stroke. Ill try that stuff this week and let you know how ...or if it works
Old Dec 29, 2008 | 10:25 PM
Kerbbirds's Avatar
The needle and seat is stuck or bad in the carb and has filled the crankcase with gas, need to change oil and fix the carb.When you get it fixed shut the gas off when its sitting so this doesnt happen again.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
