Getting fogged up
Go faster....... goggles generally only fog a low speeds, or in very cold weather (which I can only assume is the case) .......
Spy and Oakley both make snow goggles designed for skiing and they are not supposed to fog up at trails speeds..... I don't know if any goggles will stay clear if you are stopped or going very slow. They are designed to work off forced air which is only forced in if you are moving....
#15
<div class="FTQUOTE"><begin quote>Originally posted by: 700 sportsman
Mongrol, do you wear a helmet with the Turbo's, and if you don't would the straps be long enough to fit on a helmet
there's a pair on ebay due up in like 5 hours, and just want to make sure they'll work
Thanks</end quote></div>
Not sure which ones you were looking at....There's a used pair of OTG's on there...The Phenom's say they are helmet compatible.....Not sure on the OTG's
John
John
#17
The guy doesn't give much info on the ones on ebay....Not sure how old they are..Not sure if they're the Knowledge or what.......The link I posted below says these OTG's are helmet compatible......Not sure about the ebay ones......Maybe you could email the guy.....
http://www.smithoptics.com/Kno...o-Fan-OTG_14_643.html
John
John
