XP Accessory Wheels w/ Aftermarket tires
Dave
Looks like the Big horns in 14" only come in 26" 9" amd 11" Wide
I was worried that a 11" on my stock wheels would rub the sway bar. Plus I need to stay under th 48" so I can get 2 ATV's in my Toy Hauler. I'm going to get a tire groover from my Dirt Track friends and cut some extea grooves in the Stock tires.
oinkjackson,
No clutch kit (is there one available yet?), but there's only about 1/2" difference anyway:
<u>mounted, unloaded height of the the tires is:</u>
terrorthons 25.75"
bighorn 2.0s 26.25"
1/2 inch difference. Both tires at 7.0 psi
-mark
terrorthons 25.75"
bighorn 2.0s 26.25"
-mark
#15
<div class="FTQUOTE"><begin quote>Originally posted by: ManAtArms
oinkjackson,
terrorthons 25.75"
bighorn 2.0s 26.25"
-mark</end quote></div>
Great info Mark! The difference that others have found in height difference must have to do with the wheels????
oinkjackson,
terrorthons 25.75"
bighorn 2.0s 26.25"
#16
<div class="FTQUOTE"><begin quote>Originally posted by: LE850XP
Dave
I was worried that a 11" on my stock wheels would rub the sway bar. Plus I need to stay under th 48" so I can get 2 ATV's in my Toy Hauler. I'm going to get a tire groover from my Dirt Track friends and cut some extea grooves in the Stock tires.</end quote></div>
Yea, if you look back through Marks' post, you'll see that the new width is 51".
Dave
#17
not sure that theres a clutch kit available? was just wondering because when i put 27 inch xtrs on my 800 i had to add a clutch kit... but im thinking that the xp850 with its almost 20 extra hp than the 800 that a clutch kit would not be necessary. anybody have any thhoughts on this?
#18
Dave
Yeah if you want to run 11's on the stock wheels you either have to run a spacer or remove or disconnect and reposition the sway bar..
Siping can do wonders on some tires,but I think the improvements will be ok at best wiht the terriblethons..let us know..
Dave
