Sportsman Maintenance
With my SP450 carb, I let it warm up for about 10mins in any condition, after its been a rest for
awhile. One thing I would be careful of is using the CHOKE for cold starts, is not to leave the CHOKE on for warm up etc. Only use the CHOKE for just starting it and once it stays on without kunking out, then stay off the CHOKE. I learned all of this when I had developed some fouled spark plugs and reading lots of POSTS and talking with people! Supposedly NOT Good to do!
Welcome aboard and have FUN with your SP500!
R'
R'
#17
If you can, learn to change out all your fluids... oil & filter, front diff, trani, and coolant. You can do it more often, and still save yourself a lot of money... the dealers prices are ridiculous for maintenance service.
Check your tire pressure frequently.
Check your oil frequently, and don't overfill.
Check and clean (or replace) the air filter, sleeve, and air box.
Use a good sealant grease on the rubber intake when putting the air filter back in.
Check wire connections frequently, and use dielectric grease on them where possible.
Get the quad up in the air a bit, and check for loose nuts and bolts.
While it's up in the air, clean out any brush, leaves, dirt, rocks... whatever you find in all the cracks and crevices.
Make sure the vent tubes are clear of obstructions.
Learn how to "read" and change your plug.
Spray the rubber boots down with some vinyl and rubber protectant.
Use a good fuel system additive.
That's all I can think of at the moment. LOL
#18
#19
#20
