Plowing tips...
Old Jan 24, 2009 | 05:22 PM
DavidXP's Avatar
Default Plowing tips...
i personaly just push to the end of the drive in a stager......so when you go across the plow blade doesn't have a line it just nicely fills the blade insted of it overlowing and i can ussally get it in to shots and pile it high in the front of the property so far the piles only 5 ft high but i'm working on it
Old Jan 27, 2009 | 12:28 AM
Dearlh's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img]I always plow with my blade at either angle(depending on which direction I'm plowing). If you keep it straight it will "hold" too much snow in front of you and bog you down. Check back a few pages for a couple good plowing topics and pics. Have fun!!!!!
Old Jan 27, 2009 | 04:53 AM
DCT's Avatar
DCT
Banned
Not only is my driveway long, but it is wide. With my first pass, I keep the blade straight, and go right down the middle. This pushes most of the snow off to both sides. Then I angle the blade to one side... make a pass on the side with the angle... angle the blade to the other side... make a pass on that side.
With that said, I'm still fine tuning the process. However, the above seems to be the most efficient.
In extremely heavy, or deep snow, I will probably have to change it up a little bit.
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
