ecm........secondary charging system
Old Feb 18, 2009 | 02:17 AM
curby's Avatar
Default ecm........secondary charging system
well, i think my ecm is acting up!Everything else is working but the charging system.do any of you know if i can add a separate rectifier/regulator and by pass the ecm to charge the batt on a 05 sportsman 500?i found a wire up by the ecm that goes into the loom, it varies in volts with the rpm, i think its the charging wire.
if it worked till i get the new ecm.
thx mike
Old Feb 18, 2009 | 06:56 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
imo you can not by pass or put another bwside this one as the ecm does alot more then just help w/ the charging system on these newer bikes. i wouldnt even chance it of fear of doing more damage. imo.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
