'94 Sportsman won't stay in HI
Old Feb 19, 2009 | 11:04 AM
Flyingmonkey's Avatar
Default '94 Sportsman won't stay in HI
It pops out after only going a couple feet, but it always stays in low.
Is this an adjustment or something broken?
I don't use this ATV very much, infact I used it in LOW for the last year.
Thanks
Old Feb 19, 2009 | 12:46 PM
drlang's Avatar
Sorry to say you have worn parts in the transmission. It is common on that vintage. Good luck
Old Feb 19, 2009 | 02:51 PM
Hotdogmb's Avatar
You should be able to adjust the linkage for the hi range. Had to do it on my buddies 94 400 and it's still working fine with no tranny trouble. Just do a little at a time as it will throw the reverse out if you go too far. Good luck and let us know.
Old Feb 19, 2009 | 03:10 PM
Kerbbirds's Avatar
To adjust linkage, put tranny in nuetral and adjust both ends of the rods so the rod ends are precisely centered in the holes on the tranny and shifter, hope this helps.
Old Feb 19, 2009 | 09:45 PM
If linkage adjustment doesnt help then probably pinned shift forks in trans causing problems. They get slack and can usually get a positive forward or reverse only! 94 model was year affected! Replacement shift forks and shaft milled out of solid bar stock solving this problem. Hope you can adjust linkage! Replaced several kits under warranty,included shift fork and entire gear assy! Not sure if kit available or piece by piece now? Good luck
Jmuddin284
Jan 19, 2026 07:16 AM
donintennessee
Jan 8, 2021 12:40 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
black_thunder
Jul 26, 2015 09:23 PM
