Sportsman 500HO clutch kit
Old Feb 22, 2009 | 12:14 AM
ftwflh's Avatar
Default Sportsman 500HO clutch kit
best bet is to learn HOW the CVT works and tune the clutch
Old Feb 22, 2009 | 12:17 AM
Rickeyparker's Avatar
Listen to FTWFLH he speaks the truth, Once you learn how these Clutches work (Almost Impossible) then you can mover power around where you want it.
Old Feb 22, 2009 | 01:08 AM
NickDS650's Avatar
I think im gonna go with the clutch kit, lighter flyweights, and get a stronger belt to be safe, thanx guys!
Old Feb 22, 2009 | 08:08 AM
drlang's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: NickDS650
I think im gonna go with the clutch kit, lighter flyweights, and get a stronger belt to be safe, thanx guys!</end quote></div>
GIT R DONE
Old Feb 22, 2009 | 12:06 PM
  #15
red-scrambler's Avatar
i have a scrambler 500 and i put a cluth kit in it and i made a world of difference. i has a better low end and mid range now. i can climb, pull, race, and just trail ride with no problems at all. look up rick ritter at ritter cycle racing. all you have to do is tell him what you want to do and he knows exactly what you need. it only cost me like 70$. check him out
Old Jan 23, 2011 | 05:17 PM
  #16
PolarisRich's Avatar
Originally Posted by NickDS650
well stock size is 26", but i went up in width for the 26x10x12 fronts and 12x12 rears, and i dont know what the stock tire weight is, but the DDII's are 26lbs front and 30lbs rear. I feel like my sportsman is a lil lagging in the low end grunt as it is, high gear has a hard time sometimes climbin rock hills, up and over huge logs, etc. so i want that extra power, just lookin at the smartest way to go about gettin it if an exhaust doesnt do the trick
This is the exact same problem I'm having with my SP500. I have the same bike as you and I was wondering what you ended up doing with the clutching. I still have 26" but I upgraded to a wider tire (ITP Mudlite 26" XL). I thought I read in one of your other posts that you took off the EBS and you still have the kit. I need to get back some of that low end grunt!
Old Apr 21, 2018 | 07:35 AM
  #17
gpday's Avatar
Default part numbers?
Originally Posted by Rickeyparker
Get the Lighter Flyweights, I didnt want to spend the extra Money on a Clutch Kit , I installed the lighter clutch weights and that Low end lag with bigger tires has gone away and now the power curve is where it should be , In fact I cant feel any Power Dips like before and its just smooth seamless power, When i gas it it goes and there isnt that low to midrange lag it had before, Cost me 20 bucks off Ebay, And it works great, as far as the Spring goes you can get a heavier one but it will probally burn your belt or Shorten its life span. At 60 MPH I still had 500-700 RPM to go till redline but it wouldnt pull the weight up to that redline, Polaris already has the Fuel Injected Models running 95 percent max with fuel Injection, Now the carbed Models you can do alot with, get a Slip on Muffler, Rejet the carb and Index your Plug, Do some other small Mods and youve picked up maybe 4 HP.
Could you please list the part numbers for these clutch mods? Or spring color?
Old Apr 21, 2018 | 10:56 AM
  #18
Posts are originally 9 years old,these guys may not be around anymore. Plus one from 2011 wasn't answered either. Might be better to post your own thread on what you're wanting to do and you might get some updated results from current members.
Old Oct 28, 2019 | 11:38 AM
  #19
Justranchin96's Avatar
Originally Posted by drlang
Put a Polaris green spring in the primary clutch. You'll like it. I have 3 500 sportsmans running this and they all like it. Good luck
What is the part number for the green spring?
Jmuddin284
Jan 19, 2026 07:16 AM
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
