Sportsman 500, no electric start, lights and instrument panel flicker at higher rpms
Old Feb 28, 2009 | 07:08 PM
chuck_raduenz's Avatar
Default Sportsman 500, no electric start, lights and instrument panel flicker at higher rpms
the wheeler has power when you turn the key/kill switch on?
Old Feb 28, 2009 | 07:49 PM
BJ8807's Avatar
yeah but it doesnt seem like much power cuz the headlights r really dim when i turn the key on
Old Feb 28, 2009 | 07:55 PM
ok. well that sounds like an issue with the battery cable. or one of the connection ends on the cable. and the winch didnt work when you tryed to use it?
Old Feb 28, 2009 | 08:00 PM
BJ8807's Avatar
no it didnt work and the two post solenoid clicks when i push the winch buttons, the same solednoid clicks when i try starting it with the key
Old Feb 28, 2009 | 08:07 PM
  #15
so the same solinoid clickes with either switch?
Old Feb 28, 2009 | 08:25 PM
  #16
BJ8807's Avatar
yeah
Old Feb 28, 2009 | 08:53 PM
  #17
did you just get this wheeler? sounds like some major electrial issues. the wich switch will only run the 4 post solinoid, and the starter switch will only run the 2 post solinoid. other than that im flusterd. i still think its the battery cable. but if the switch is running more than one thing it sounds like wireing issues.
Old Feb 28, 2009 | 08:56 PM
  #18
BJ8807's Avatar
ok well if the four post is the winch then its the starter solenoid that clicks and i apprecitate you taking the time. i got a manual and when it warms up im going to take the side panels off and follow wirings and check em to the wiring diagrams.
Old Feb 28, 2009 | 09:05 PM
  #19
if you have a wire diagram id say follow that. but yes if its rectangle, black about 2inches thick, has 4 posts it will be the winch solinoid. so id say chck the wires. but check the main batter cable, for cracks, croshion and stuff. sorry i couldnt be of more help.
4xrider
Apr 10, 2017 01:36 PM
rmx251
Sep 10, 2000 11:40 PM
foxkill
Jul 24, 2000 01:21 PM
mrdci
Feb 7, 2000 07:16 PM
mrdci
Dec 4, 1999 11:03 PM
