Is a SC500 faster than a SC400 2 stroke??
Old Feb 10, 2001 | 10:54 PM
jefffoxsr's Avatar
Anyone ever line these two up? Also, how often does the top end need to be rebuilt on the 400? Thanks.
Old Feb 10, 2001 | 11:25 PM
Xplor's Avatar
Pretty much the same speed. Most of the mags gave the 500 an extra MPH on top. Keep in mind that with only a couple hundred dollars, the 400 will waste the 500. As for rebuilds...not too sure.
Brian
Old Feb 10, 2001 | 11:41 PM
CaptNemo's Avatar
A new Wiseco piston and gaskets with a bore job and a hone will set you back about $ 200.00.
As for the life span of the engine, it all depends on how you ride, modifications, if your jetting is a little on the rich side, etc.
A little oil pre-mixed into the fuel and letting the engine warm up to operating temp before riding will go a long way to keeping the engine alive.
A pipe and clutch kit brings the 400 to life, less than $ 400.00 turn it into a monster.
Old Feb 11, 2001 | 02:49 AM
No2StrokeBs's Avatar
no
Old Feb 11, 2001 | 09:32 AM
jefffoxsr's Avatar
Thanks for your comments.
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
