Newbie
Old Mar 5, 2009 | 11:44 AM
MEGA XP's Avatar
Default Newbie
Nice machine, Where will you be doing most of your riding? What state you from? I'm from SD you can ride em on the street here too.
Old Mar 5, 2009 | 11:58 AM
knackll's Avatar
Default Newbie
Thank you!!
The SS isn't the fastestes thing under the sun but it'll run up against quite a bit out there and it is absolutely a fun ride to drive. Great in the snow and tows too.
Old Mar 5, 2009 | 12:27 PM
knackll's Avatar
Default Newbie
The details are as follows:
K&S MOTORCYCLE TURN SIGNAL HEADLIGHT SWITCH Part# 12-0055
K&S MOTORCYCLE ATV LED FLASHER BLINKER WINKER RELAY SWITCH Part# 24-0005
K&S MOTORCYCLE HORN 12V UNIVERSAL MOUNT Part# 11-0150
2 BLACK LED RED & BLACK AMBER Motorcycle Turn Signal lights (From Bestblueheadlights Ebay item# 250380290383).
I really liked the K&S switch since it looks stock, as if it was made to match up against the stock Polaris switch. I bought the Polaris work light option on Ebay which is nothing more than 2 912 bulbs and a toggle switch (which I did not need) I wired the new K&S switch directly to the Polaris work light switch under the pod. Using the K&S switch helped me from having to cut a hole in my pod for the toggle switch, possibly scratching or breaking it. I'm using the high beam switch (on K&S switch) to turn it on or off. There is a little blue indicator light on top of the K&S switch that lets me know if the work lights are on.
The turn signal relay and horn is K&S brand. I kept it the same so they would play nice together. I liked the turn signals because the are small LED and the are very brite when lit. The other thing is they are not over powering and are small & white when not in use so as to not obstruct the appearance of the atv. No big red & amber reflectors. BTW, the rear turns are red & the fronts are amber when lit. Otherwise they are clear/white when off.
Wiring is simple 16 gauge wire that I used a snake to run wires from the pod down though & past the gas tank. I did wire the turn signals directly to the battery with a inline waterproof fuse holder (10 gauge wire) so as to not disturb the Polaris' electrical system. The only time I connected to the electrical system was to connect 2 lead wires from the K&S switch (high beam wire) to the polairs work light connector under the pod. Basically 2 spade terminals pushed into the Polaris switch.
There is a guy out there that does do turn signal kits and was extremely helpful, but unfortunately I wasn't able to use his product because the K&S switch wasn't compatable with his relays.
To me, the look is very clean, which is what I wanted. I do understand that it is an ATV and should be in 4 ft of mud, but it is nice to cruise out on the street once in a while without the hassel of the local sheriff stopping me because it's not street legal. Either way, it worked out well.
Hope this helps.
knackll
Old Mar 5, 2009 | 01:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Newbie
welcome to the forum and 800 club. enjoy the ride amd be safe.
Old Mar 5, 2009 | 03:32 PM
  #15
Default Newbie
Hey welcome to the forum. You'll get alot of useful and some not so useful info here.
Old Mar 5, 2009 | 04:38 PM
  #16
DCT's Avatar
DCT
Banned
Default Newbie
Sweet quad. Must be nice being able to ride it on the streets.
Good luck with it.
Old Mar 5, 2009 | 10:35 PM
  #17
1200bruce's Avatar
Default Newbie
Now if we could just find a few slip-ons for the Touring model to chose from I'd be happy! I have a Stealth Black 08!
Old Mar 6, 2009 | 05:34 AM
  #18
rancher55's Avatar
Default Newbie
Welcome knackll, That's a good looking 800!
Old Mar 6, 2009 | 08:26 AM
  #19
*5 J's*'s Avatar
Default Newbie
thanks knackll -
Are the white dots, that appear to be about the size of a quarter, just inside your rear light pod and underneath your front grill the led for the turn signals?
Where did you install the horn?
Where did you purchase the K&S products?
<div class="FTQUOTE"><begin quote>Originally posted by: knackll
Hope this helps.
knackll</end quote></div>
Old Mar 6, 2009 | 11:29 AM
  #20
knackll's Avatar
Default Newbie
Yes, that's them.
The horn is tucked up underneath the gas take area.
I purchased the K&S products on Ebay.
Check this out:
Item number: 140305600825
& Here is the relay:
Item number: 140304474614
Hope this helps.
knackll
