Changing contactor for winch
Old Mar 8, 2009 | 08:39 PM
Rattletrap2's Avatar
Default Changing contactor for winch
May be a stupid question, but here goes anyways!
I will be replacing the contactor for my winch soon and if I disconnect the battery cable, will I loose the stored data in my console, such as hours, mileage, etc.
I have the electronic console on my 2007 500 EFI Deluxe.
Thanks!
Old Mar 8, 2009 | 08:44 PM
eggenz7's Avatar
as far as i know you will not loose that data. it has a battery in it i believe
Old Mar 8, 2009 | 08:54 PM
firehog's Avatar
eggenz7 is right, there is a battery back up in the pod that stores your info, so no worries....
Old Mar 8, 2009 | 08:55 PM
chuck_raduenz's Avatar
the oem data on the speedometer pod?
Old Mar 8, 2009 | 09:12 PM
Thanks folks, yes, it is the info that is stored on the handlebar pod that |I was worried about.
In order to change out the contactor, I would like to disconnect the battery first because it is tight to work in there and I have to slightly modify the control wires (Black and Green). The connector is different on the new one.
Old Mar 8, 2009 | 09:16 PM
yes it will keep the info. other wise it be easy to say a wheeler had zero miles and hrs on it when you sell it. its just like a car display it will keep all the info. i kinda doubt theres a battery inside tho. but it will keep the info. no worrys.
chuck
Old Mar 9, 2009 | 07:40 AM
One more hint is don't leave any jewelry on your hands when doing this. Especially on the X2. I made quite a connection between the battery post, my wedding ring, and the engine. It burned about 1/8 of flesh off my ring finger.
Old Mar 9, 2009 | 07:54 AM
Thanks for the tip.
I once saw a guy working under a car dash when that happened. He burned fingers on his other hand trying to get the ring off as well!
ylomnstr
Sep 22, 2015 12:19 AM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
Jason Campbell
Sep 7, 2015 02:25 PM
toonces
Sep 5, 2015 01:14 PM
