Clutch removal??????
Old Mar 23, 2009 | 12:21 PM
mikesgood4u's Avatar
Default Clutch removal??????
I removed the center bolt and slid a 6" 3/8's extention into the hole that the bolt came out of and I have tapped it several time, I have even sprayed pb blaster into it.... still not comming off.... and sugestions??
Old Mar 23, 2009 | 12:34 PM
ZAKAZIM's Avatar
There is a polaris puller you have to have to do this. I got my puller off Ebay.
http://cgi.ebay.com/ebaymotors...Q5fPartsQ5fAccessories
Old Mar 23, 2009 | 01:29 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: mikesgood4u
I removed the center bolt and slid a 6" 3/8's extention into the hole that the bolt came out of and I have tapped it several time, I have even sprayed pb blaster into it.... still not comming off.... and sugestions??</end quote></div>
you need a clutch puller that goes into the center where you took the bolt out. it WILL NOT come off any othr way w/ out damaging the clutch.
Old Mar 23, 2009 | 03:41 PM
teamplayer's Avatar
If you are handy, you can make your own puller with 9" long piece of 3/4" <u>FINE </u>thread rod and two nuts jamed or welded to the end.
Old Mar 23, 2009 | 04:27 PM
scrambler400enoge's Avatar
Shapeshifter Rider
When I had my clutches removed by the dealer he used an air drill for the primary,and a slide hammer for the secondary.
Old Mar 23, 2009 | 08:21 PM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Just the old clutch puller, fat and stubby, after you break the primary off, make sure you use some Emory cloth to clean the cranks shaft up
Old Mar 23, 2009 | 10:47 PM
eggenz7's Avatar
the secondary should just slide right off. its on a coarse splined shaft. very easy to remove. but you will need a puller to get the drive clutch off. whether it be a homemade one or a storebought one. that bolt in the middle is torqued around 50 ft lbs. take that pressure over a couple of heat/cool cycles and its stuck pretty good.
Old Jul 6, 2009 | 06:40 PM
1greenhornet's Avatar
Eggenz7,
I just ordered the secondary clutch buttons and wanted to get some clarification on any special tools I will need to install them.
Anything else I need to check while I have it off?
Thanks,
Scott
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
