high alt. jetting?
Old Mar 27, 2009 | 09:56 PM
Wenty's Avatar
Default high alt. jetting?
Heading to the big horn mts this fall bow hunting
..elevation will be around 8500 to 9000. Will we need to rejet?
Machines are a 400 xploler and 500 ho.
Old Mar 27, 2009 | 11:34 PM
tregtom's Avatar
From: Central Valley Ca 1.5 hr to the Sierra Mts & 2 hrs to Pismo Beach
Put a "Dial-a-Jet" on the carb. That way you can adjust for alt. on the fly.
Old Mar 28, 2009 | 06:43 AM
MaineWheeler's Avatar
Go to Holtzman.com as there are far better options then dial a jet systems such as their ATACC set up = (Automatic Temperature and Altitude Carburetor Compensator) which frees you from potentially costly human error. They specialize in a variety of carb stuff stuff, mainly sled but also do ATV's and if they don't have what you want there are other manufacturers with the same idea and principles. If your dead set on a Dial A Jet system I have a used one that is complete that I took off of my machine because I was NOT HAPPY with the what to me was constant fiddling with it I wanted a set it and forget it type system- New they run you $75.+, I'll let you have my used one for $25. shipping included BUT like I posted I recommend calling Holtzman - your call
Old Mar 28, 2009 | 09:03 AM
Speeddrive1's Avatar
Call a local dealer out in the bighorns and ask them what they recomend.
Old Mar 28, 2009 | 02:54 PM
Kerbbirds's Avatar
big horns in wyoming, where did u get the quad if u bought it up in casper, they already did the high altitude jetting and clutching
Old Mar 28, 2009 | 08:39 PM
Wenty's Avatar
We're from MN. Casper? We drew elk tags for the bow season...they should be in full rut...sweet.
Just curious if anyone knows what jets we should run...they're cheap, easy to change for one week
We'll need it, we don't need any dial a jet or "spendy" alternative.
Any help is much appreciated.
Old Mar 28, 2009 | 10:04 PM
when we went to colorado last year I called a local polaris dealer where we were going to ride and they were more than happy to tell me what jets to use.
Be warned tho, even with jetting they are going to be doggy but shouldn't be a problem.
http://www.dxgillette.com/
Here is a polaris dealer in gillette wyo that should be able to help.
Old Mar 29, 2009 | 10:29 PM
Kerbbirds's Avatar
on the 500 HO, i know its the 147.5 main jet, the explorer, not sure on. good luck on the hunt, just remember don't bugle too much, a lot of cow calling
Old Mar 30, 2009 | 10:11 PM
Wenty's Avatar
Thanks for the info guys...I'll call a dealer out there, that along with what info I gain here will get us set up.
Kerbbirds...been doing lots of research on the hunt itself, have heard the same, don't bugle much, mainly in the early am to pinpoint their position...make our move...cow call to pull them close. It's going to be a great hunt, harvest or not!! There will be 4 of us total, split up, each of us will have a caller and someone to help glass. 7 months away and I'm already itching!! Being our first year applying we weren't expecting to get drawn, with the average bull between 280 and 340 with several 350+ taken each year we're pumped. Still waiting to get drawn in New Mexico...that might be many years though!
Old Mar 31, 2009 | 12:52 AM
Kerbmonster's Avatar
ya, it's a good time, we don't hunt up there, but our mtns are so much closer to us, up there huntin in 45 minutes
