my 911ep led stars, wireing and so on.....
#31
heres some pics of the work light leds and brake lights leds. im also in the process of chaning my swiches and making my work lights come on it reverse:
worklight bulb
taillight
old switch pannel
new idea switch panel
i ended up having to fix the plastic so it didnt leave a hole. since the oem cut out was lower. dont look to bad. but it will work tell i find a new red pod. the top switch will be my rev/off/worl light switch, bottom will be my flashing light on/off switch and im thinking tailights kill switch.
worklight bulb
taillight
old switch pannel
#33
soldering iron. and pieces of the plastic from the cut outs. dont look the best. but its better than a hole. if i find a cheap enough pod ill get that one and change it. i still need to drill a hole for the indacator light for the top switch. it will go right above where i fixed the big hole. and the bottom switch i need to drill the one hole bigger and another like the hand thumb warmer switchs on the left for indacator lights. i also got alabel maker to change the icons on the switch.
400H0
10
Aug 20, 2015 07:34 PM
Jul 21, 2015 03:03 PM
