sSportsman XP 550 VIBRATIONS AND RATTLES????
A lot of horse's in a small package
And there's no excuse for it. The engineers at Polaris must have been on coffee brake during that test. LOL They could have done better... and probably will.
Anyhow, I've talked to a couple of guys locally that have walked away from a 550 for just that reason. One of them was right at the dealership. I know I would pass on one for just that reason. I'm sure it's a great quad otherwise, but that kind of stuff drives me crazy.
This noise concerned me too at first but i got use to it , now the ticking noise my dodge caravan makes when i start it just drives me nuts.
I think in the Polaris 550 it's the Horse's giving a couple kicks when you wake them up,all 40 of them.
Yours does not make a noise like a small motor spinning around right after turning it off? I have been on 3 different 550's and all 3 made this noise. It reminds me of the same noise as I used to hear when turning off my brute 750 I had. I enjoy the 550 more than my 800. It is the best all around quad I ever drove. IMO
#15
Fuel pumps on EFI engines are connected through the oil pressure switch and they are usually live even with the key off.The fuel pump should run for a few seconds after shutting the engine off,until the oil pressure drops and turns off the switch.
In this manner it wo`nt start until the oil pressure is sufficient to turn on the fuel pump.
#16
The 850 starts up and runs as smooth as silk... and that's 70 HP... and my point exactly. Polaris could have done the same thing with the 550, and I bet they will.
#17
Whatever the case, I prefer the smooth delivery of power. I'm not buying that the 550 shakes and rattles because it is a HP motor... especially when a couple of folks have said they have no shakes or rattles.
#18
#19
#20
Just thinking about the noise a shutoff, I never paid attention to it because it is the fuel pump. If you cycle the key on without starting it wait 5 seconds and then turn it back off you will here the noise. This is how I Know I have waited long enough in the cold weather starting procedure. After you here the fuel pump reset then your goo to give it another on cycle to get more fuel for start up.
