NGK equivalent spark plug
Old Apr 3, 2009 | 01:19 PM
04sportsman600's Avatar
Default NGK equivalent spark plug
Hey guys,
I am wondering what the NGK equivalent plug is to Champion plug in a 2004.5 Sportsman 600? I went to Canadian Tire at lunch to buy a new set and their computers said it was a BKR5E. Is that correct, I thought I read on here somewhere that it was different like a higher heat range...
Also can anyone explain why they call it a 2004.5 Sportsman? Were some changes introduced halfway through the year?
Thanks,
Paul.
Old Apr 3, 2009 | 01:33 PM
TLC's Avatar
TLC
Look in Canadian Tire's book in the spark plug section. Look up your NGK plug and beside that it should list the AC,Bosh,Champion and motomaster equivalent of the NGK plug.
I think 04.5 was the point Polaris went from the locking two hub AWD system over to the exploding single front diff AWD plastic roller cage setup and they added the troublesome ECM brain box that can quite like a light bulb at anytime.
Old Apr 3, 2009 | 05:36 PM
la90043's Avatar
I'm pretty sure if you go here http://sparkplugs.com/default.asp you'll be able to cross reference the plug.
Old Apr 3, 2009 | 05:55 PM
DCT's Avatar
DCT
Banned
According to the 2004 owners manual (not sure if 2004.5 is different) the 600 calls for a RC7YC. The NGK cross ref is a BKR7E.
BTW, the BKR5E is listed for the 400 & 500 for that year.
Old Apr 3, 2009 | 06:02 PM
DODGE57HEMI's Avatar
Mopar Man!
Polaris has switch to NGK plug as there OEM part! Just curious why you would wana switch any way? IMO the NGK's are a far superior plug!
Old Apr 3, 2009 | 06:14 PM
TLC's Avatar
TLC
Thats odd . My Clymer's maual that covers sp500
96-03 says
96-97 BKR5ES
98-01 BKR5E
02-03 BKR6E
But the 500 H.O motor never changed since 2001 to current.
Old Apr 3, 2009 | 06:25 PM
DCT's Avatar
DCT
Banned
96-03 says
96-97 BKR5ES
98-01 BKR5E
02-03 BKR6E
He has a 600.
Here's part of the page (copied and pasted)
MAINTENANCE AND LUBRICATION
Spark Plugs
 Use BKR5E spark plugs for the Sportsman 400 and 500.
 Use RC7YC spark plugs for the Sportsman 600 and 700.
 Proper electrode gap is .035″ (.90 mm).
 Spark plug torque is 18 ft. lbs. (24 Nm).
Old Apr 3, 2009 | 06:33 PM
TLC's Avatar
TLC
I never totally trusted my Clymer manual after it try to tell me I had to remover both clutch pulleys and the back plate to remove the starter? LOL
Old Apr 3, 2009 | 07:01 PM
plumbob's Avatar
BKR7E is the cross for the NGK plug for all the twins.Early 500's called for the BKR5E and the H.O's and later singles call for the BKR6E.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
