2000 Magnum 325 Knock
Old Apr 6, 2009 | 02:13 PM
Bfcnb's Avatar
Default 2000 Magnum 325 Knock
Hey all,
I got a 00 325 Magnum with a knock, The strange part is that it only knocks above idle and is weak. The wheeler would idol all day and sound good but as soon as you touch the throttle it knocks... Anything common on these?
Old Apr 6, 2009 | 04:37 PM
ftwflh's Avatar
They are a loud motor but check the primary clutch buttons for play
Old Apr 6, 2009 | 04:49 PM
TLC's Avatar
TLC
My 500 knocks at idle from the water pump ,but it disappears above idle.
Old Apr 6, 2009 | 05:15 PM
Bfcnb's Avatar
I'll check the clutch... This is a loud knock though, it makes you think the engine is going to go...
Old Apr 7, 2009 | 06:07 AM
ftwflh's Avatar
the 325s did have a rod bearing issue
Old Apr 7, 2009 | 06:28 AM
Kerbbirds's Avatar
Do you have a stehescope? You can use a large screw-driver, place the tip on the engine and the handle at your ear and maybe you can pinpoint the area the knock is coming from, hopefully the crank bearings arent bad and the pistons not hitting the head.
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
