00 sportsman 500 starting problem
Old Apr 9, 2009 | 10:46 PM
BARKERR's Avatar
Question 00 sportsman 500 starting problem
When pushing start button nothing happens no crank,noise,nothing have to pull start.after driving it may start with button,but very intermidently.having to pull strt 90%of the time.Any switch or electrical problems known?Thanks,any help would be appreciated.
Old Apr 10, 2009 | 01:56 AM
BillR's Avatar
Make sure your battery is good before looking elsewhere. Once checked then go from there. Check your solinoid, if all rusty on the outside chance it could be there as it was a bad part
Old Apr 10, 2009 | 06:14 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
like mentioned check battery and if dead charge it first and then maybe check contacts on the push button as they can get dirty or corrode over time. check all connectins from battery to starter,though the solenoide to make sure the same as connections goes.
Old Apr 10, 2009 | 01:06 PM
btatum's Avatar
My wife's 500 is doing the same thing.. or was. it was the fuses not getting a good connection, I pulled them all and di-electric greased them all and now is fine.
whitty
67
Feb 24, 2021 02:52 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
