1999 Polaris scrambler 4x4 500 coolant leak?
Old Apr 30, 2009 | 01:41 PM
hondafl350's Avatar
Question 1999 Polaris scrambler 4x4 500 coolant leak?
Hi I am having a problem with my 1999 Polaris scrambler 500 4x4 it seams that the coolant is leaking in to the pull starter what could cause this and is it a heard fix and is it common problem?
Old May 1, 2009 | 12:37 AM
itch's Avatar
water pump seal ?
Old May 1, 2009 | 07:17 AM
Kerbbirds's Avatar
Ditto on the pump seal, needs to be replaced cause the water will eventually mess up the stator or other elctronics on that side.
Old May 1, 2009 | 12:55 PM
hondafl350's Avatar
Question
This is the 500 four stroke HO. I know the water pump is behind the flywheel on the 400 2 cycle I know this because I did one. Is the water pump in the same place on the 500? It looks to be on the outside of the pull starter cover. Is the 500 behind the flywheel?
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
Coryco
Jul 6, 2015 07:30 PM
