02 Sportman 500 Stalls when fan kicks on
My 02 500 either stalls or runs rough when the fan kicks on. If it does stall I have a real low spark on the plug when using the starter and it wont start. I can get it to start with the pull start. My first thought is a bad ground on the fan circuit? Any suggestions would be great.
Check the voltage of the battery.Shoud be around 12.5 volts or so,If not then charge the battery and check the operation of the machine.When running and at above idle{1200 to 1500RPMs}the battery voltage should be around 13.5 volts.
If voltages are correct then start looking for grounding issues.
Running the machine with a bad battery can fry the stator.
Quadzilla Heritage
09-25-2015 01:39 PM
