500 is hot
Old May 8, 2009 | 09:19 PM
08 rap's Avatar
well i jumped the fan and it works fine so that means its ?
Old May 8, 2009 | 10:16 PM
200es's Avatar
Default fan
bad sencer, the plug in the top of your rad controls when your fan turns on, maybe bad connection?
Old May 11, 2009 | 06:13 PM
08 rap's Avatar
is the pll cord suposed to have oil in it? if not do i have a blown crank seal?
Old May 11, 2009 | 07:03 PM
200es's Avatar
Default pull cord
no the pull cord should not have any oil in it. more then likely bad seal.
Old May 11, 2009 | 09:36 PM
  #15
Pous's Avatar
As for the ticking noise in the engine it may be a stretched timing chain. Could have possibly ran it overheating for a while and stretched it, i did it to mine a couple of months ago.
Old May 12, 2009 | 07:15 AM
  #16
Kerbbirds's Avatar
Want to make it run better? Get the cylinder measured first to see how much oversize you need. get a wiseco 11 to 1 piston and rings for it, stock is 10.2 to 1 then buy the ho cam and a 40mm carb and boots for a 2001 or newer 500ho, it will add quite a bit of power for around $500 bucks if you do the work yourself, Can usually find a carb on e-bay I would get a new cam and check the rocker arms for wear.
