clecking noise in reverse
Old May 9, 2009 | 06:38 AM
island hunter's Avatar
Default clecking noise in reverse
2003 400 sportsman.I have a clicking noise on the front in reverse when i'm on an incline or towing in reverse.Would it be bad u-joints.
If so does anybody have parts # for NAPA.If i'm going to replace one i might as well do the prop shaft and the other two up front.
Or should i be looking for another problem?
Old May 9, 2009 | 06:47 AM
ftwflh's Avatar
Sounds more like a CV joint going bad.
Old May 9, 2009 | 07:12 AM
switzomatic's Avatar
Default Clicking
In addition to checking your cv's, take a look at front wheel bearings, balljoints, and the ujoints. Check out ebay if you need any of them. Pretty good deals on there.
Old May 9, 2009 | 07:18 AM
Kerbbirds's Avatar
Front drveline u-joints are a napa# 338,probably is a c-v joint, if so call the c-v man 1-800-338-2326 he also sells on e-bay, good products good service,
Old May 10, 2009 | 06:33 AM
Thanks guys.I decided to change my hub fluids and take it all apart and noticed i have a crack in my roller cage in the hub,so i think i found where the clicking noise is coming from when in AWD in reverse.Should i look any further.
Old May 10, 2009 | 06:36 AM
Default Clicking
It wouldn't hurt to check it out while you have it apart.
Old May 10, 2009 | 06:54 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
havent heard of too many people having a roller cage cracked and clicking n the hub. check your bearings good while you have it apart as well. imo
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
r1pilot83
Sep 27, 2015 07:38 PM
