Homemade Stuff on your Quad
Old May 14, 2009 | 03:28 PM
FunRide's Avatar
Originally Posted by 700 sportsman
and here's my favorite the Strobe Light's
700....What's up with the strobe lights?
Old May 14, 2009 | 03:29 PM
700 sportsman's Avatar
for plowin and stuff in the winter
I had the normal work lights in there, and took them out, and these strobes fit in those holes, and you can turn them on solid, so I guess in a way I got strobes and led worklights all in one
Old May 14, 2009 | 03:31 PM
FunRide's Avatar
Originally Posted by chuck_raduenz
heres my sprayer mounted and bumper
Chuck, that's a sweet looking spray rig. Looks factory. Bumper and the rest is pretty cool too. You must be a master of the mig. Thanks for the pics.
Old May 14, 2009 | 05:24 PM
XJCraver's Avatar
Yes yes, Chuck, thanks for the pics!!! Your projects look great, and have given me some ideas. Hope you don't mind if I borrow some!
700 - Your stuff looks great too.
Keep them pics comin' fella's, I really dig this homebrew stuff.
-J
Old May 14, 2009 | 07:14 PM
  #15
Homemade wood box to extend the height of my X2 box. 1/4" aluminum bolted to my floorboards to protect them. Took a chunk out of original left side when it got pinched between a rock and a tree.
Old May 14, 2009 | 08:11 PM
  #16
DarrenWS6's Avatar
I just have a luggage rack that my friend made. Turned out real well and even has a mat. Its a bolt on like any other, and the mat is velco held.
Old May 14, 2009 | 09:33 PM
  #17
FunRide's Avatar
for plowin and stuff in the winter. I had the normal work lights in there, and took them out, and these strobes fit in those holes, and you can turn them on solid
You can turn them on solid. That makes sense now.
Old May 15, 2009 | 12:27 AM
  #18
chuck_raduenz's Avatar
nice strobes. least you can turn them into work lights. but think if i used them here id be getting a ticket. since there cant be no white flashing. i got led work lights and rear ledstrobes. great work tho. i like the shift **** 700 has also.
the spray i now am trying to mount on my new wheeler. hopefully by the end of this week. i have 3 yards to spray for weeds. and i will add pics of it when i get it mounted.
my bumper is pretty heavy duty. i had a police push bumper on it to push cars around when i had a job working on police cars. we also did other repairs. but i was layed of from there. but my bumper just started out as a regular bumper no wich. then in 2006 i got a 1500lb winch for free. and i just welded 2 plates across, and 2 small pieces of steel for the rollar faring to mount to. drilled holes for the winch. it worked awsome it fit perfectly under the plastic polaris bumper.
now see if i can finish where i left off:
but since were adding video. heres a video of my old 335. a week before i sold it:
here is my winch grill cut out and 2 of the 6 led stars i added to the wheeler. all the switches for my worklights, and flashers are on the headlight pod.
here are the rear flashers. mine didntcome with red reflective tape so i cut my own out and added:
side flashers. one on each side:
and here is my custum made licence the letters on the plate are also made by me and cut out by me. plate and licence plate bracket. along with a 911ep ls12. it has brake and flashing patterns. vary nice add on.
here was my original switches before my handwarmers/tumbwarmers were added.
after may hand warmers were added:
and now the way my switches look. i hada fill in some of the other holes to make it look better. but dont look to bad if i do say so my self. i also like the look of all the switches being the same. all the switches have a led to tell me its on. top switch on right side is my work light, off, reverse light. so i can turn the work lights on/off or have them come on in just rev. under that one is my led flashers, off, and not used at the moment switch:
my fuse block finished:
the rearend lighing finished:
my orginal plow had black trip springs. i have since changed it to 3 other springs. since i hit a hidden rock while plowing and almost kissed the front rack. so i added 2 first but it tripped to easy. i added another and isent bad:
my tow hook:
my draw bar:
Old May 15, 2009 | 12:28 AM
  #19
video of my wheeler with the lights and what not:
older videos of when it was about a week old.
i also added a alum dimond plate guard. well it pretty much just for lookes under the winch, on the bottom of the polaris plastic bumper:
here is the second vershion of my pull behind grader/box scraper. ihave regrets i changed it now. since i like the way it was the first time. but not much i can do about it now. the box scraper is a earthcavator from the 70's and is made by gannon. i can lift and lower the grader or scraper via a 12v toggle switch i have on the rack:
my led brake light bulb:
led work light bulb:
my trailer. paid $100 for it. i added sides (removable if needed), home made dimond plate alum fenders, 13 led marker lights, and i got regular taillights for it. but i removed the guts of the taillights and made leds for the inside of it. since i like leds. if you noticed that. i just added a new plywood bed and bed bolts. i wanted something that was hidden when not in use so i got the bed bolts. ill add pics later:
Old May 15, 2009 | 12:32 AM
  #20
this is pics of not my wheeler but a video of a local police atv. had 3 red and 3 blue lights added. this thing looks mean.....
