Rear Axle Rebuild....No Chain Adjustment....
Old May 19, 2009 | 08:56 AM
jjump's Avatar
I see where you thought I might be loosening the axle nuts...
That is a seperate problem. Besides not being able to adjust the chain. I can hear a grinding, almost like a roller from the bearing is getting caught up in soemthing...
I did spray the nuts, in anticipation that I may have to remove them....
Old May 19, 2009 | 10:14 AM
itch's Avatar
Originally Posted by drlang
To turn the carrier you only need to loosen 2 bolts, then turn the carrier not the axle. Unlees I'm reading something wrong here it sounds like he is trying to loosen the axle nuts.
plus the caliper bolts
Old May 19, 2009 | 10:22 AM
itch's Avatar
remove the bolts completley from both the swingarm and the caliper and bend the carrier tabs a little the aluminum carrier likes to get corroded and oxidized and it freezes in place. remove the sprocket side hub,axle nut ,sprocket holder, and sprocket leave the brake side intact and slide the carrier/axle as a unit out the left side of the swingarm (brake caliper side)
its much easier to change the carrier bearings with everything on the bench
Old May 19, 2009 | 10:24 AM
drlang's Avatar
That all sounds right then, I use a large channel lock on the carrier. Spray it down well with some penetrating oil and giver again, as far as the axle nuts they are a pain on scramblers.
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
