97 scrambler issues
Old May 25, 2009 | 08:47 PM
firemedicsafd's Avatar
Default 97 scrambler issues
I have some problems with my scrammy...after sinking it in a mud hole, i found it not running,( DUH!) i cleaned the carb, no luck, changed the fuel including the filter, no luck, changed the oil...twice...no luck. i NEED it to run. It will start after LONG attempts and it idles high...but will not turn the wheels when throttle is given, and starts to die unless i let off the gas. A friend told me the magneto is going bad...this would be the third if it is true. Another friend told me it was the CDI...which would be the thrid also. What is going on? Any help out there? I dont want to shoot it and start over....i promise i will get something more reliable....but i want to sell thisto help pay for the new one. Thanks alot!
Old May 25, 2009 | 09:11 PM
itch's Avatar
[QUOTE=firemedicsafd;2798152]I have some problems with my scrammy...after sinking it in a mud hole, i found it not running,( DUH!) i cleaned the carb, no luck, changed the fuel including the filter, no luck, changed the oil...twice...no luck. i NEED it to run. It will start after LONG attempts and it idles high...[/QUOTE
i'm confused "you found it not running" and it wont run, but then you say it starts but idles high
were you actually riding it when it stopped in the mudhole and would not re-start or started hard but would not move under its own power
Old May 25, 2009 | 09:14 PM
once she stopped on me, i got her out cleaned as much as i could and so far...after all that i have done to it...i cant get it to run right. sorry for the confusion
Old May 25, 2009 | 09:19 PM
itch's Avatar
how deep was it
did it suck in water thru intake or up over the exhaust?
is your air filter wet
Old May 28, 2009 | 09:35 PM
Not to my knowledge. The filter was k&n so it kept the water out. The problem I noticed was when i tried to start it, she would pour fuel out of the exhaust manifold. I cleaned and replaced jets in the carb and tried again. It would start but would not go past idle when throttle was applied. The fuel and filter were replaced with no success.
scram5050
Aug 30, 2024 01:39 PM
raceware
Jul 30, 2015 06:59 AM
DeFox500
Jul 26, 2015 06:32 PM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 13, 2015 05:11 PM
