How many miles on your Polaris and any issues?
Old Jun 1, 2009 | 09:05 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Two Sp 450's (2006) mine has around 3000 miles now and on third ECM or PDM or Sure Power Module or "Black Box" whatever you want to call it(all free!!)......great other than that............Caper........
Old Jun 1, 2009 | 09:25 PM
Snedd800's Avatar
Got about 900 miles on. Overheated twice- replaced tstat 1st time, 2nd was water pump leak, all on warranty. Ran pretty good for a couple months, moved into ext. warranty...fan quit working, $50 dect., started hearing some loud noises in the clutch, dealer put it on computer and cleaned it up.., now I'm dealing with the thing not wanting to idle. Tried new plugs and seemed ok for about 150 miles or so then started doing it again, cable is good and tight, plugs still look good, air filter is new. It's just not wanting to idle under about 2200 rpm, shuts right off. Seems like the fuel is getting cut out or something. Dealer looked at it, put it on computer...nothing... it's been sitting for a couple weeks now. I'm going to put in some new gas, dealer sed to try fuel injector cleaner, Ill try that too. I'll see how it runs tomorrow, I have about a 70 mile trip planned. Hopefully I make the trip this time. Last ride I made it 8 miles and couldn't keep the dam thing running. I was with two Can-am 800's too. I took quite a bashing over that one.
Old Jun 1, 2009 | 09:51 PM
cherokee99's Avatar
friend of a friend bought 08 500 new in December. January- overheated in -10 degree weather. leaked fluid. February- tie rod snapped in middle of turn. late march- just rideing along and fried the wire loom. all electronics where toast! all fixed under warranty all occoured under 100hours. now the kid doesnt wana ride it anymore, dont blame him.he had a 325magnium for 7years with no problem....
Old Jun 1, 2009 | 09:54 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
1,100 on the 05 sportsman - replaced brakes , tires and one CV boot (All normal wear items).
Old Jun 1, 2009 | 10:43 PM
  #15
bentarrow's Avatar
First Things First!
We have 2 02 SP500's, both with over 3700 miles. Both have had new belts because of our riding style. Replaced 1 boot on each quad and my carb is flooding and leaking from the over flow probably from dirt.
My wifes 850XP has 225 miles and the only trouble with it is she goes to fast, otherwise its perfect
Old Jun 2, 2009 | 06:31 AM
  #16
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Chuck, what did they say about the fuel sensor? I have similar issue, stays at 3/4 tank, they told me that the float could be hanging up on the inside, take a hanger and see if you can pull away. Well, that's a Poo shop for yah, and their "ageless" tools and certified fix!! I took the tank off, and you need a surgeon to extract the fuel assembly
Old Jun 2, 2009 | 07:57 AM
  #17
hddoperator's Avatar
Mine has about 250 miles on it now and ZERO problems. The wifes machine has about 200 miles on it and we fought electrical problems when it was still under warranty. It ended up being a wire harness that was rubbed through by the heatshield. Also have had trouble with one rear wheel staying tight (I think the dealer messed it up on day one). Oh...and the ecm fell off of its mount and was hanging by the wire harness when the machine had less than 5 hrs. on it... Lately all seems well...we'll see!
Old Jun 2, 2009 | 08:41 AM
  #18
colt2245p's Avatar
5500 hard miles in 6 years on the 01.........replaced speed sensor 3 times.....3 sets of rear wheel bearings........4 broke bolts on the right rear a arm..........new front driveshaft..............several sets of brakes................3 sets of tires............replaced strecthed chain in transmission..........1 belt at 3500 miles................motor was never touched except for oil changes and air filter cleaning always k&n filter
Old Jun 2, 2009 | 09:27 AM
  #19
snosnake's Avatar
2140 miles on an 09 550xp. No problems.
Old Jun 2, 2009 | 09:35 AM
  #20
Cryokid's Avatar
Thumbs up 2004 Sportsman 400
I have over 4,000 miles on my machine and the ONLY thing I had to replace was my battery and the "Warn" contactor.
It has been troubles free since i bought it new.
A hell of a good machine!
