02 sports 500 ho
Old Jul 3, 2009 | 12:27 AM
chuck_raduenz's Avatar
dose it go full speed in rev?
Old Jul 3, 2009 | 12:33 AM
avengermike's Avatar
Seems to but if I put it in high she will move for a sec then start cuttin in and out and not really move any more same for low although I can move around in that gear but as Soon as I hit full throttle she cuts in and out. As if I would need to hold overide button down to get full power
Old Jul 3, 2009 | 12:42 AM
i cant rember on the 2000 sportsman i had. if id go forward and push the over ride if it spit an sputter. try wireing the purplr and the gray/orange back together and drive it in forward.
Old Jul 3, 2009 | 12:47 AM
Will do thank u if post back with my findings , other question is their a wire on the speedo that I can give 12v or sometype of voltage so it thinks it's reading movement from the bike? I'm sure that's my problem my yamaha is like that the wire to the speedo came un hooked and the bike kinda went into a limp mode
Old Jul 3, 2009 | 01:07 AM
  #15
the only wires i can see causing an issue would be that gray/orn. other than that there are really no other wire that would cause an issue with it being powerless in forward. but like i said splice the 2 wires back together and drive in forward. if it drive great get a double throw switch so you can turn it on and off. and add a switch to the awd so it can be turned on and off when needed.
and if that all dont work there maybe something else that happend when it was fliped.
Old Jul 3, 2009 | 11:18 AM
  #16
okay so before i hooked anything back up i tried reverse and i dont have full power, even tried the override switch after hooking it all back to stock still no. did notice with the brown/white wire grounded from speedo, when in reverse i can hit the override switch and i have awd in reverse and awd turns on when in gear now. but i still dont have power going forward
Old Jul 3, 2009 | 08:03 PM
  #17
lil update, so i had the 4x4 going and was messing with the quad when i pulled the air box lid and started the bike up, it runs alot better now but top end is surging so im thinking the fuel/air mix maybe off. bad part i lost 4x4 some how... do u have any ideas, and how would i lean it or richin it?
Sep 30, 2015 01:37 AM
Hack714
Sep 26, 2015 08:11 AM
cboler9
Sep 24, 2015 08:35 PM
kampswas
Sep 23, 2015 05:05 AM
Hack714
Sep 20, 2015 05:54 PM
