proper oil gas mix
Old Aug 23, 2009 | 12:30 PM
musclecarnut74's Avatar
Default proper oil gas mix
i have a 1996 polaris 300 xplorer and i want to start mixing my gas and oil myself. not wanting to trust the injector anymore. does anyone no the best or oem mix. i also am having trouble with my shifter staying forward to keep the 4 wheel drive engauged, no problems in two wheel drive. any adjustments or should i replace the whole shifter thx
Last edited by musclecarnut74; Aug 23, 2009 at 01:49 PM. Reason: accidentley put sportsman
Old Aug 23, 2009 | 12:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
40 to 1 is a good mixture. is the linkage adjustable on the lever.
Old Aug 23, 2009 | 02:13 PM
Doctorturbo's Avatar
GOT BOOST!
What stendori said. I run 40 to 1; (50 to 1 on cold days), on every two stroke I have ever ran. Never locked one up in my life. Even on engines like leaf blowers that are wide open for an hour at a time.
Never ran any special oil. Always bought what was cheapest and never had a problem. Still have a 50 year old chainsaw.
Old Aug 23, 2009 | 08:16 PM
hoytultratec's Avatar
why get rid of the oil injection? never burned up polaris motor because of a failed oil pump if your worried about it because of age rebuild it ive owned 3 2 strokers Plus I hate premixing. make sure you block off the oil pump if you premix.
Old Aug 23, 2009 | 09:49 PM
carlobee's Avatar
40 to 1 , like what stendori and Doctorturbo said, would be fine.
Divergent12
Dec 30, 2017 08:33 PM
craacker
Sep 9, 2015 04:32 AM
Pahuntman
Sep 5, 2015 11:07 AM
ylomnstr
Sep 4, 2015 05:02 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
