Question from the new guy
Old Aug 30, 2009 | 10:52 PM
gooch1979's Avatar
Default Question from the new guy
My wifes got a 2001 trailblazer 250 and at 3/4 to full throttle it hesitates and loses power. I put a new plug in it and no help. What do you think? Coil, revbox? Any help would be great.
Thanks
gooch1979
Old Aug 31, 2009 | 02:47 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check the carb main jet to see if partialy plugged or if the float leevl is correct? when you say hesitate, does it back fire, cut out like loosing fire, or bog out? how did the plug look that you replaced?
Old Aug 31, 2009 | 03:21 PM
gooch1979's Avatar
Have not checket the carb. It feels like its loseing fire. like when you have a bad plug wire or coil on a car. Only cuts out at a high RPM.
Old Aug 31, 2009 | 05:53 PM
eggenz7's Avatar
try holding down the over ride button when this happens. if it clears up then remove the black wire on the rev limiter box. might even just remove the wire to bypass the switch
Old Sep 1, 2009 | 08:12 AM
gooch1979's Avatar
Thanks, I'll give it a try.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
