Gas Tank Vent?
Old Sep 14, 2009 | 11:41 AM
Ragelite's Avatar
I have 4 ft of line but my prob is that I dont know where to run it. The guys at the dealership dont know either. Your saying down the steering stem? Not sure what you mean. I had it running to the back of the back untill last night when I saw it was filled with mud from the ride the day before.
Old Sep 14, 2009 | 11:46 AM
gumbyman's Avatar
it wont matter where you put it as line goes up before you go down ... higher then tank after that who cares as long as it clears heat and rubbing on something
Old Sep 14, 2009 | 12:13 PM
Ragelite's Avatar
And why is that? Sorry first ATV Ive owned so its all new to me.
So should I still loop it in the pod? and run it to the back?
Thanks
Old Sep 14, 2009 | 12:22 PM
gumbyman's Avatar
you dont have to go into the pod if you dont want too... it has to go higher so that the fuel wont act like a syphon.... laws of gravity... with it higher the air will escape and enter before the fuel letting... it to balance itself as the level drops.....
Old Sep 14, 2009 | 12:24 PM
  #15
scootergptx's Avatar
Supersock
Hired Gun!
Imagine being an a hillside with a full tank of gas. If the vent line doesn't go up higher than the tank, you just may wind up with a siphon.
On mine, there's a clip on the steering stem just below the pod. You can see where the hose would go down through that after it looped over the bars.
Old Sep 14, 2009 | 12:29 PM
  #16
Ragelite's Avatar
LOL very true, but I almost have to go into the pod, the vent comes right on on top of the tank and the next highest spot would be in the pod.
So your hose goes right into the stem?
When you guys overfill your bikes do you ever notice gas leaking out the vent line?
Old Sep 14, 2009 | 12:30 PM
  #17
Supersock
Hired Gun!
Not sure if it would solve the odor problems, but you could always plug the tank line and just go with a vented cap.
Old Sep 14, 2009 | 12:35 PM
  #18
gumbyman's Avatar
oh ya you can get some fuel to come out if you take the time and fill it to the neck... as for the smell it will be there.... i notice it more when i have my windshield on....but throttle it up burn the gogo juice.... and you froget all about the drips and smell....
  #19
Ragelite's Avatar
But if I run to the pod and loop it and run down the steering stem I shouldn't smell gas right so problem solved. Im going to look at it tonight with the pod off.
What do you guys think about putting a check valve on it for when Im in deep water or mud?
Old Sep 14, 2009 | 12:37 PM
  #20
gumbyman's Avatar
you'll be good to go.... no check valve... it wont suck up anything...
