Rebuilt top end-had good compression, now I don't????
Old 10-01-2009, 08:14 PM
As long it was premixed,shouldn't be the issue! Would still have adequate lubrication until pump caught up and then would just smoke a little extra.
  #32
Old 10-01-2009, 08:30 PM
kellyisu's Avatar
So, I've completed the top and lower end rebuild, having trouble finding the source of the low top end compression.
  #33
Old 10-01-2009, 10:06 PM
UTU's Avatar
UTU
UTU is offline
Crank seals??????Bad???????
  #34
Old 10-01-2009, 10:22 PM
kellyisu's Avatar
Nope- new seals- they are in correctly
Thanks though
  #35
Old 10-01-2009, 11:47 PM
Doctorturbo's Avatar
GOT BOOST!
Whats low? Lets have a compression number.
Have you done a leakdown on it. You can listen for an air leak or see the % of leakdown.
  #36
Old 10-02-2009, 05:56 AM
kellyisu's Avatar
Low enough to where I can keep my finger over the spark plug hole when turning motor over. Low enough to where I didn't even need a compression tester to realize that was the problem.
Havn't done a leakdown but I will. Don't see the gaskets leaking though. When I rebuilt the top end I put new ones in, then I put new ones in again when I redid the bottom end just in case.
  #37
Old 10-02-2009, 04:05 PM
kellyisu's Avatar
Well, I thought I was getting fuel, now not so sure. Gonna go spray some gas through the carb or dip the spark plug end in fuel tonight to see if it fires up.
****Is it possible that if the motor is not getting gas or the right fuel/air mix for the top end to lose compression after losing good lubrication ( I lubed the motor well during rebuild) from trying to check for good compression before trying the initial firing of the motor on the rebuild? Thus, causing the rings not to seat right away, losing good lubrication, and leading to loss of top end compression?
I wonder if my carb adjustments are off?????????????????????
  #38
Old 10-02-2009, 11:43 PM
kellyisu's Avatar
Heck with it, I'm just gonna repull the top end tomarrow. So much fun.
  #39
Old 10-03-2009, 11:53 AM
GOT BOOST!
Do the leakdown first. That way you know if you have a ring problem.
  #40
Old 10-03-2009, 12:04 PM
kellyisu's Avatar
Do I need to get an actual compessor and leak down tester to do this or are there other ways?
Quick Reply: Rebuilt top end-had good compression, now I don't????
