1996 magnum 425
1996 magnum 425
Hi all,
Im new to this forum and have a question. my father in-law has a 1996 425 magnum. Its in the shop right now and is requiring 2500.00 worth of work because the transmission is shot!!! The quad only has 450 miles on it! Anyways, my friend says he believes he should have been squeezing the brake lever while shifting in and out of gear, his polaris requires you to do this. Does anyone here know if polaris recommends for shifting to squeeze the brake lever on a '96 magnum??
I have been trying to find the answer to this and have been coming up empty handed.
Thanks
Thanks
holding the vrake lever would have nothing to do w/ the transmission at all. only a few years in the 2003 and up(not sure what years it was for sure) you had to pull the brake to get it out park and maybe gears, but it still shouldnt have anything to do w/ it unless he had the engine reved up or idled too high. but it would grind gears or shift into gear hard. but there again that still would not require any brakes. imo.
Yeah i know, I was in the room when he was on the phone with the shop, very long list of broken parts. He has been looking for a used trans without any luck. 2500 to fix a 96 is rediculous but the fact that it only has 400 miles I think hes better off fixing it then scrapping it and buying someone elses problems. thanks again
POLARIS 96 SPORTSMAN MAGNUM 4X4 TRANNY TRANSMISSION:eBay Motors (item 320429196345 end time Oct-04-09 17:36:50 PDT)
