Rear wheel. How much play?
Old Oct 5, 2009 | 03:35 PM
09 popo HO's Avatar
Default Rear wheel. How much play?
Since I pulled off my bad rear wheel to get it repaired (see other post) I decided since the rear is jacked up I'll inspect the other wheel.
When I grab the wheel at the 3 and 9 oclock position there is no play but at 12 and 6 there is some movement. I can't remember the ball joint/wheel bearing rule. does this mean my hub nut isn't torqued proper or possibly a bad bearing. My quad is only 7 months old with 60hrs.
Thanks in advance. I know you guys will pull through again.
Old Oct 5, 2009 | 04:57 PM
RickCJ7's Avatar
the wheel bearings all have a little play, sure its not the bushings?
Old Oct 5, 2009 | 07:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there is some play which is normal, not sure how much you have.
Old Oct 5, 2009 | 07:26 PM
09 popo HO's Avatar
pushing and pulling on the tire (25" stock) it's probaly rocking at least 1cm. I will check again tomorrow and also put a tourqe wrench to the hub retaining nut to ensure it's at 80ft/lbs.
My rear end is jacked up right now so I cant check the front and dont have the other back wheel right now to use as a reference. For all I know they all have some play and I'm over re-acting.
Old Oct 6, 2009 | 03:45 PM
09 popo HO's Avatar
Ok so I checked it today and I was overestimating the play. There is only a mm or 2 play when push/pulling the hub. The right side wheel has no play at all.
I was thinking the hub retaining nut maybe not torqed enough. Ive never messed with a drive hub before. Only trailer hubs in the past and I never torqed them down so I am aprehensive about putting 80 ftlbs to this badboy.
Anyone know what size socket the rear retaining nut is. I need to buy one because nothing in my garage is that big.
mywifesquad
8
Sep 21, 2015 08:20 AM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
