Crank bearing Q's??
Old Oct 5, 2009 | 10:51 PM
dakotav8's Avatar
Default Crank bearing Q's??
Hi, On my 250 trail boss do you press off the worm gear for the oil pump seperate for the bearing or both at once? Thanks
Old Oct 6, 2009 | 04:41 PM
I heat the devil out of the worm gear,slip a big bearing separator behind the bearing and knock down ,moving the bearing and gear a little,then using my press to finish the job in removing gear and bearing. Then when its time for a new bearing (After crank has cooled) I lightly heat the new bearing,usually slips on,if not then have a punch handy to tap on race and seat the bearing. As far as the worm gear install ,MUST be super hot again and usually just drop on in place. Other people have different ways,but both can come off at the same time.
Propane torch really handy along with a hot plate for the worm gear(if you have it) or just heat thoroughly with torch and use gloves or pliers to pick up worm gear and drop on shaft. (shaft is tapered and worm gear just drops against bearing,when cool,CANT budge it)
OPT
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
black798
Sep 9, 2015 07:42 AM
DM2015
Sep 7, 2015 10:36 AM
Elkaholic
Sep 6, 2015 02:44 PM
