Stabilizer Bar Bushings
Old Oct 6, 2009 | 07:54 AM
PWN's Avatar
PWN
Default Stabilizer Bar Bushings
2002 Sportsman 500
I want to change the stabilizer bar bushings (#15 in the picture). I am rebuilding my rear suspension, and have the whole rear torn down right now. The only thing I cant remove is this bar. It seems like its all one piece. I am confused.......
Old Oct 6, 2009 | 05:17 PM
After you remove both stabilizer bar supports the bar should just knock out of the sleeve. It is just one piece! Sometimes the bar can get a little bent ,but still should come out. OPT
Old Oct 7, 2009 | 07:46 AM
PWN's Avatar
PWN
Thanks! Thats what I wanted to know.
Old Oct 7, 2009 | 09:57 AM
gaspumpcity's Avatar
Leave it out if you want more suspension travel. If you want to go fast around corners leave it in. Humm someone need to invent another quick disconnect sway-bar.
Old Oct 7, 2009 | 11:33 AM
GTSnoRacer's Avatar
how important is it that these bushings stay oriented properly?
noticed mine were cracked and split on my 6 month old machine, now the replacements keep shiftong..maybe i don't have the vertical bars tight enough? i didn't want to split the bushings when i installed them
Customer Service #1
May 15, 2020 08:46 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
Elkaholic
Sep 6, 2015 02:44 PM
