electric problem
Old Oct 6, 2009 | 11:51 AM
allan744's Avatar
Question electric problem
I have a 2006 sportsman500 x2 my taillights stay on when the key is off also noticed that I can trun my headlights on whenthe key is in the off postion. Ihad put a diode on my light so I could use both high and low beams together. found no broken wires would it be in the PDM
thanks Al
Old Oct 6, 2009 | 06:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you try unhooking the mod you put in to see if that is the reason for the odd lights being on? shouldn't be any power through the key switch until its tunred on unless the switch is bad or been wired somewhere wrong. imo
Old Oct 6, 2009 | 08:19 PM
allan744's Avatar
I unhooked every option that I had put on. but thanks any way I am stumped
Old Oct 6, 2009 | 08:31 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
May be getting power through a HOT wire touching ground.......Rubbing somewhere...............
Unhook your black wire from the battery and with a volt/ohm meter using the volts DC scale...........put on test led on the frame and the other on the black ground wire.................if you getting any voltage reading...........your getting power leakage through your ground wire........Caper...........
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
