Transmission drain plug hits chain
Old Nov 10, 2009 | 04:57 PM
Oldman800's Avatar
I guess the Silent chain will keep streching until it wear's a hole thru the case.
Good point, does the chain continue to loosen until it starts wearing through the case?
Old Nov 11, 2009 | 05:15 PM
williamk's Avatar
Taking mine to dealer next week for same problem. Asked them what has been changed to fix problem. Dealer said part # for chain has changed, so thats all the info. I got from him. Guess I will try it and see. Fixing it under warranty.
Old Nov 11, 2009 | 05:20 PM
700 sportsman's Avatar
keep us informed william, I'm intrested to see what has been changed
Old Nov 26, 2009 | 11:39 AM
williamk's Avatar
just picked up the biike today and the mechanic said that the new chain is alot tighter and shouldnt hit on the drain plug. Guess I will find out when I change transmission oil again. Will post my findings.
Old Nov 26, 2009 | 12:07 PM
  #15
If you don't mind me asking, how much did it cost you for the chain and labor to install it?
Old Nov 26, 2009 | 12:41 PM
  #16
williamk's Avatar
was under warranty, so paid the $50. just checked bill and chain is listed at $66 CDN. no price for drain plug.
Old Jun 14, 2010 | 11:27 AM
  #17
Effer's Avatar
I found this forum while searching this topic.
Just wondering if the only thing that needs to be replaced is the chain to correct this problem?
Any tips/suggestions for a DIY'er ?
Thanks in advance for your help/info.
Effer
Old Jun 22, 2010 | 12:44 PM
  #18
Effer's Avatar
nevermind... it all went Ok without a shop manual or any recommendations/suggestions.
Old Jun 22, 2010 | 05:31 PM
  #19
stendori's Avatar
Super Quad Patrol
I'm watching you!
glad you got it figured out and sorry someone didn't get back to you in time.
Old Jun 22, 2010 | 06:51 PM
  #20
WilliamBos's Avatar
Originally Posted by stendori
if you did a search you would have seen a few post on this and i put a pic as well showing the plug. there is no adjustment for the chain. i know its extremly loose(hence why its rubbing on the plug)
Is this on the 800 only? Or all Sportsman's?
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
SDR-II
Sep 29, 2015 01:06 AM
Sjrpp
Jul 5, 2015 09:04 PM
