Clutch problems
Old Oct 16, 2009 | 08:12 PM
bydarb's Avatar
Default Clutch problems
I have a problem with the belt slipping on my 1999 sportsman 5oo when i go through water even a little bit of water. Somebody suggested that my clutch could be adjusted to tighten the belt. Is this possible and how and has anybody else had problems with their belts slipping.
Old Oct 17, 2009 | 03:40 AM
helmethair78's Avatar
Have you inspected your belt for wear???
Old Oct 17, 2009 | 04:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are the belt could be worn out if it has some age on it or it may be glazed over as well. i would take clutch cover off and inspect the belt and clean clutches. the belt should be sitting about 1/8" above the secondary(driven)clutch. also the clutch cover shouldn't be letting water in unless it has a bad seal so you may want to get a new seal or least check the gasket thats in there.
Old Oct 17, 2009 | 06:39 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Easy way to check for water behind the cover is to remove the Red nut on the back of the cover by left rear tire. Stendori has it nailed down for yah, and you will want to rebuild the clutches if Water is getting past the cover seal.
Old Oct 17, 2009 | 09:01 AM
ftwflh's Avatar
be sure all the intakes and exhaust tubes are on and zipped tied tight
Old Oct 17, 2009 | 03:30 PM
bydarb's Avatar
Hey thanks for the help Ill check it out.
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
