Disable overide/ 4 Pin relay
Old Oct 21, 2009 | 10:12 AM
issac4049's Avatar
Default Disable overide/ 4 Pin relay
the Napa part # is AR294 for the 4 pin relay, you can also use shrink sleave to make a water tight seal on the connections.
Old Oct 21, 2009 | 03:58 PM
700 sportsman's Avatar
what year models are you talking about, and also, some info on what wires to hook together, and so on would be helpful
Old Oct 22, 2009 | 07:59 AM
issac4049's Avatar
Default Disable override/ 4 pin relay
I have an 06 500 efi and it was also posted to work on an 03 700
#30 connect brown
#87 connect gray/ orange
#86 connect red/white
#85 connect purple
Old Oct 22, 2009 | 02:36 PM
I'm assuming this is all in the pod?
Old Oct 22, 2009 | 04:51 PM
issac4049's Avatar
I wired mine up under the speedometer housing.
SyTye
Sep 11, 2015 02:45 PM
sweaver
11
Aug 18, 2015 03:47 PM
Bratman2
Jul 23, 2015 12:36 PM
cornermike
Jul 8, 2015 11:44 PM
clsharky
Jun 8, 2015 11:38 AM
