Predator torque specs
Old Nov 1, 2009 | 06:41 PM
rich250rracer's Avatar
Default Predator torque specs
I'm rebuilding the top end on an '05 Predator. Can somebody give me the torque specs for the cylinder/cylinder head bolts and the cam cap bolts? Also, what is recommended valve clearance? Thanks.
Old Nov 1, 2009 | 07:22 PM
700 sportsman's Avatar
I have the 03 predator service manual, but they wouldn't be the same would they?
Old Nov 1, 2009 | 10:41 PM
I believe it's the same motor, so specs should be the same.
Old Nov 2, 2009 | 09:30 AM
94harley's Avatar
Cam support bolts 6.6-7.5 ft lbs
Valve lash Intake .006 Exhaust .010
Torque to(criss cross pattern)
22 ft lbs, then 51 ft lbs, then leave sit for 1 minute, loosen 360 degrees(1 turn), Torque to 29ft lbs, Then evenly tighten 90 degrees, then another 90 degrees and your done.
6 lbs on the 6 mm bolts
Old Nov 2, 2009 | 07:02 PM
Thanks.
Old Nov 2, 2009 | 09:57 PM
popoman's Avatar
just an FYI for those torque specs. Just from them saying turn the bolt 90 degrees and then 90 degrees again sounds as though they may be torque to yield bolts. which means if they are they are only good for one use. TTY bolts actually stretch to make their most clamping force and do not shirnk back when loosened. Buy new head bolts if you havnt already or atleast check with someone to see if they are TTY. Dont reuse a TTY bolt.
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
raman8tor
Sep 20, 2015 07:35 AM
